X-Carve Pro Instructions / 4x2 / Connect Computer
12. Connect Computer
During this step you will be connecting your computer to the X-Carve Pro and using the gantry’s motion to square the machine. You will need an internet connection to finish the assembly and setup your X-Carve Pro.
At this point of the assembly, you should not have the wasteboard installed and the Y2 side should be loose. Easel will guide you through the final assembly steps.
First, you will need to create a new Easel account or log in using an existing account.
Easel Login
Once your account it setup, and you’re logged in you will need to download and install the correct drivers to your computer to allow it to connect to the X-Carve Pro. All users need to download and install the Easel Driver.
If your computer runs Windows, you will need to install the FTDI driver as well. You can access all driver downloads here:
Easel Downloads
Once the two drivers are installed, re-launch your browser and return to this step.
Before continuing, ensure that there is nothing on or within 12 inches (300mm) of the X-Carve Pro or table on all sides.
Note: The Y1 end of the gantry extends 8 inches (200mm) past the end of the machine. Ensure there are at least 12 inches (300mm) of space at the back of the machine to allow your gantry room to not crash into anything.
Note: Easel will guide you through installing the washboard in Step 13 during the Easel Setup.
Tools
  • Computer
  • Internet connection
  • Easel login credentials
  • X-Carve Pro Serial Number
Cables
  • USB-A to USB-C - 2M
  • USB-A to USB-C adapter (if needed)
Steps
  1. Connect Your Computer to the X-Carve Pro
    • Using the included 2M USB-C to USB-A cable, connect your computer to the front of the HMI.
      NOTE: If your computer only has USB-C ports, use the supplied USB-A to USB-C adapter. At this time, using a USB-C to USB-C cable will not allow the computer to connect properly. The USB-C part of the adapter should connect to your computer.
  2. Use Easel to continue X-Carve Pro setup. These steps will be guided and include:
    • Logging into Easel (use an existing account or start a free trial with a new account)
    • Square and home the machine
    • Install and plane the wasteboard
Locate Your X-Carve Pro Serial Number
All X-Carve Pro units have a unique serial number. This serial number helps to distinguish and identify between the numerous X-Carve Pro machines in use. You can add your machine’s serial number in Easel under your Machine Settings.
You can find the serial number for your X-Carve Pro machine on a sticker located underneath the gantry, closest to the Y1 axis. When looking at the machine from the front, the Y1 axis will be on the left-hand side.
The video below shows where the serial number is located on each machine.
Clicking on next step will guide you through the last assembly steps to square your machine and install the wasteboard via Easel. Ensure you have enough time to complete assembly all the way through. If you proceed to the final step but do not complete it, you will have to open Easel's Toolbox to uninstall the machine profile from Easel then return to this step.
Next step: Finish setup with Easel
