The X-Carve Pro is packaged so components can be removed from the box as assembly is occurring. There is no need to unpack everything prior to assembly.
For any questions or issues during assembly, please contact Inventables Hardware Support team via help@inventables.com or visit our X-Carve Pro support pages.
Video
X-Carve Pro Components
Tool kit
| Description |
Qty |
Image |
Notes |
¼” Drive Hex Bits
3mm, 4mm, 5mm
¼” Drive Deep Sockets
12
4mm, 4.5mm, 5mm, 5.5mm, 6mm, 7mm, 8mm, 9mm, 10mm, 11mm, 12mm, 13mm
¼” Drive Socket Wrench
Red handle
Allen Key Set
1.5mm, 2mm, 2.5mm, 3mm, 4mm, 5mm, 6mm
¼” Drive Torque Wrench
Open end wrenches
7mm, 11mm, 13mm, 17mm x2, 22mm
Top section
| Description |
Qty |
Notes |
Crossmembers with Leveling Feet
Crossmembers without feet
Level
4 feet
Square
Drag Chain
HMI
Middle Section
| Description |
Qty |
Notes |
Y1 Axis Assembly
Y2 Axis Assembly
Has slot for dust collection
Gantry Assembly
Clamp Extensions
Packaged under Y-axes
Dust Collection
Dust Hose Assembly
Dust Shoe
Hardware Bag - Please review and confirm correct quantities and parts prior to assembly.
| Description |
Qty |
Image |
Notes |
Socket Head Cap Screws (SHCS) M5X16
18
Button Head Socket Screws (BHSS) M5X16
Socket Head Cap Screws (SHCS) w/ Spring Washer M5x16
32
Socket Head Cap Screws (SHCS) M5X22
Red paint on socket head
Socket Head Cap Screws (SHCS) M5X25
Spring Washer D5
10
Flat Washer D5
18
Zip Ties
⅛” Collet
Cables
| Description |
Qty |
Image |
Notes |
Controller Power Cable
RJ45 Cable
For HMI Connection
USB-A to USB-C
2 meters
USB-A to USB-C
3 meters
USB-C to USB-A Adapter
Y1 Limit Switch Cable
Y2 Limit Switch Cable
Y1 Motor Cable
Y2 Motor Cable
Drag Chain Plate
Z-Probe
Cable with clip and brass disc
Easel will guide you through installing the wasteboard in Step 13 during the Easel Setup. |
Bottom Section
| Description |
Qty |
Image |
Notes |
T-Slot Wasteboard Quadrants with Threaded Inserts
Next step: Prepare for Assembly
